跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
iPhone not activating after update failure
My iPhone was working perfectly fine yesterday morning. I decided to update to iOS 14.0.1 using Finder on Mac. The update failed midway (error 14) and the update and restore function failed the same way, so I restored it. iOS successfully installed, but now it says “It may take a few minutes to activate your iPhone.” It has said this for hours. I have tried restoring it with a PC as well, but had the same problem.
Some water damage occurred back in March, mostly affecting the screen and speaker. I took it apart and cleaned and dried it well, and then it worked fine (except for the speaker) up until yesterday morning. I was on call with Apple for a few hours and the best they could do is let me send it in, but because of the water damage they quoted >$300. Could it be possible that the water damage is causing this issue? Should I take it apart and check for corrosion and other issues?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
So after doing nothing for hours, it said “Unable to Activate” on my phone. I left it on that screen and connected it to my Mac, and it somehow activated through there. Resolved! For anyone who finds this in the future, try just leaving it on that screen for a while. Apple. It just works.
这个答案有帮助吗?
得分 0
添加一条评论
Liquid damage could be a factor here depending on how severe it was. If it got a few drops of rain on it, it should be fine. But if it went for a swim in a toilet then it may be a bit of a long shot. Liquid damage isn’t very economical because no matter how much you clean it and no matter what you replace, there will always be an issue, or “gremlin” as we call it, waiting to show its ugly face and this may be the one. I always compare liquid damage to getting a stain on your favorite shirt. What do you do when that happens? You treat it immediately. When electronics get wet they need to be opened and diagnosed ASAP. Rice and other desiccants can’t absorb the liquid fast enough and they leave behind any impurities in said liquid that can cause short circuits.
这个答案有帮助吗?
得分 0
2条评论:
I did open it, take everything out, clean it with rubbing alcohol and dry it within hours after it was exposed to water. There were significant blobs in the screen and residue in the case, which may give a hint to how severe the exposure was. But considering everything else was clean and dry when it was put back together, I'm not sure if I can write the phone off just because of the water damage
完成的
did you remove the shields that are soldered on? Liquid can get trapped under those as well
完成的
添加一条评论
添加你的答案
Sith Siri 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 74
