跳转到主内容
Repair information for the LG G7 ThinQ smartphone. Released in June of 2018. Model numbers: G710EAW, G710N, G710EM, G710AWM, G710EMW, G710TM, G710ULM, G710VMX, G710PM, G710VM.
29 个问题 查看全部
Why are there lines on my screen when I do certain things? >>
When I turn my phone on after its been off for awhile it has vertical white lines on it. Also when my screen is dark (not the brightness) but for example if im playing a game and it goes black for a second it will have lines but fade away when the screen is bright again. My phone screen is already damaged it has black spoltches at the bottom but i haven’t found anything on google. Thank you! :)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi,
I think that you have answered your own question as to what the problem is. “My phone screen is already damaged it has black spoltches at the bottom”.
To me this is just another sign that there are internal problems in the screen.
As a DIY repair all you can do is to temporarily replace the screen and check.
Here’s a video that shows how to do this, which may help.
Note that the ifixit LG G7 ThinQ 拆解 guide shows that the repairability score of the phone is 4 out of 10 (with 10 being the easiest) and also says as a negative: Screen repair, the most common type repair, is not prioritized, requiring an almost complete disassembly while battling tough adhesive, so it won’t be that easy
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
angelinamangeri8 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 19
总计 276
