跳转到主内容
Noise cancelling headphones, line in.
2 个问题 查看全部
My battery does not seem to be making contact inside the headphones
I purchased these about a year ago, so the warranty is out. Already checked for normal things like wires disconnected, and corrosion. I did a thorough cleaning with vinager and still nothing. Then I noticed when I put the battery in, and pushed down hard on the top, the green light came on. This worked a few times, and am wondering why it is doing that. Recently I had them sitting on a table, no drops or falls to cause something to be dislodged…
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I had the issue with a pair in which the battery had been left during storage. As often happens with those copper-colored batteries, it leaked. I was able to apply a few drops of white vinegar to the spring and spring holder in the little door to the compartment, then rinse and repeat without getting liquid inside the headphones. I also used an emery board to brighten the part of the spring that contacts the battery. Again, don't get dust inside. Even though you cleaned it, there could be a little bit of corrosion where the spring is held in place or where the electricity flows into the headset, or on the tip of the spring. I put in a new battery and they worked!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
image blue 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 13
总计 259
