跳转到主内容
What is up with my Display?
Guys this is what happened to my Macbook Pro and I was wondering if anyone knows what is the best solution
1) Opened Macbook one morning after making some coffee and the screen was white with a gray halo around it… it was just frozen there.
2) I restarted the Mac and the screen was now totally black. I plugged it into my external Asus Display and found the laptop itself to be functioning properly!! apart from display
3) I went into system preferences “display” and it wont even identify the macbook monitor only the external one
4) Webcam works fine and even lights up when it is on
5) The Back apple light is always off
6) I have tried all software resets and nothing works so this is defo a hardware issue
How can I for sure fix this problem? What should I order and do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Aim a flash light in through the lids Apple Logo, do you see a faint image of your desktop and its icons?
完成的
Hi Dan. There is no faint images at all. In system preferences it won't even recognise the display.
完成的
添加一条评论
2个答案
最有帮助的答案
This looks like the same issue: MacBook Pro won't detect internal display
这个答案有帮助吗?
得分 1
添加一条评论
@luiz.pinheiro83 - At this point you’ll need to pop the bottom cover and inspect the internal display connection to see if it’s damaged if not you’ll need a new display assembly.
Follow thins guide to Step 9 MacBook Pro 13" Retina Display Early 2013 Display Assembly Replacement then jump down to Step 14 inspect the connection thoroughly.
Sadly, If you don’t see any then you’ll need to get a new display assembly.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
luiz.pinheiro83 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 108
