跳转到主内容
The Kenwood Chef A701A is a stand food mixer released by Kenwood.
47 个问题 查看全部
please can anyone advise on the number of shims on the motor armature
how many shims are there on the motor armature at the bottom end near the control board?
I have removed the armature from the housing and I am not sure how many shims there were.
thanks
Bill24
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Hi @bill24 ,
According to the parts list in the service manual (see p.25-26) there is a small packing washer - part #184, one large shim washer - part #183 and a nylon armature washer - part #186.
Hopefully this is of some help.
这个答案有帮助吗?
得分 1
1条评论:
If you look at the service manual quantities, there should be _two_ of the small packing washers (part #184). There may also be another between the other side of the bearing and the fan, if required, to take up any vertical play.
完成的
添加一条评论
添加你的答案
William Broome 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 8
总计 120
