跳转到主内容
A digital TV converter box by Apex Digital.
Power Light won't stay on
Apex DT502 digital converter box is hooked up. But when I press the “ON” button — either from the remote or on the box itself — the light turns from red to green, then immediately back to red. It won’t stay green at all. If I press and hold the power button on the box, it just flashes red. Any solutions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi,
It seems as though it is either going into some sort of protect mode or perhaps there is a problem with the power supply in the box.
I cannot find a service manual or schematic for the box online so you may just have to open the box and initially check the power board for any obvious component damage such as heat stressed components, bulging or blown capacitors and dry solder joints on the back of the board.
Here’s the ifixit Apex Digital DTV Converter Box Power supply Board replacement guide that may or may not be of some help. I don’t think that it is the same model as yours (possibly a DT-250A?) but hopefully it is similar enough to be of some help.
If you see something wrong and/or you’re not quite sure, post some close up images back here. Here’s how to do this 在已经存在的问题里加入图片
Apex Digital DTV Converter Box Power Board图片
指南
难度:
简单
iFixit图片
指南
在已经存在的问题里加入图片
难度:
非常容易
2 - 5 minutes
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
farmerzdtr 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 625
