跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2397 个问题 查看全部
Why is the Home Button loose after screen replacement?
I purchased the front panel replacement recently from ifixit, and last night I had a chance to replace my shattered screen (*tear*). Anyways I get done with the entire process and when I turn around my phone to admire my new shiny screen, I notice the home button is loose! I'm not sure if loose is the correct word but it seems as if it's deflated? If you tap it with the edge of your nail it will rock back and forth like a see-saw. The button overall still works, but this is super annoying.
My question, could it be something I missed during reassembly? And if so does anybody have an idea what it could have been? I looked at the comments on the guide and no one is mentioning this issue.
A second thought, this display seems thicker compared to my last display, but I haven't confirmed this yet. I received my phone on its release so I'm curious if something has changed in the parts since then.
I know a tear down is imminent, but I don't want to go down that road without knowing what to fix, or a suitable hack I could try to make it better.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
5个答案
最有帮助的答案
Yes sir, a teardown is indeed imminent. Sometimes when you replace the digitiser assembly the home button is not lodged correctly. Easy fix. All you need to do is take off the screen and make sure the home button is secure before you tighten it back up.
This exact issue has happened to me many times before i eventually started to test the home button before i actually replaced the screws.
Hope this helps :D
这个答案有帮助吗?
得分 1
添加一条评论
I had the same problem. Discovered after taking if apart several times I had s longer screen holding the plate in. It needs two short screws. Solved my loose button problem. Good luck.
这个答案有帮助吗?
得分 1
添加一条评论
mines is loose and screen still loose
这个答案有帮助吗?
得分 1
添加一条评论
Same problem here. Its ridiculous. They won't sell the screen with the home button even if you ask them to. And this pretty much always happens with the 4S.
这个答案有帮助吗?
得分 0
添加一条评论
I sent my cracked screen to a local shop to get repaired but they have broken the home button! I'm thinking of asking the shop guys to repair it, as they were the ones who broke it. But I'm not sure that I have a guarantee
这个答案有帮助吗?
得分 0
1条评论:
I just replaced my screen/lcd on a 5c and my home button is still working but slightly loose.. Just took it back apart and tried to resecure the button but didn't seem to make a difference. May have to reglue around it?
完成的
添加一条评论
添加你的答案
bobop10 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 11
总计 21,757
