跳转到主内容
Computer crash then no signal on monitor
This happens to me randomly occurs when im gaming my specs are
GIGABYTE DS3H MOBO
RX580 8GB XFX
GSKILL AEGIS 2x8gb RAM
Ryzen 5 2600
Corsair psu 500w
I also have an SSD and a HDD
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Hi,
Presumably the screens works again after you restart the computer, is this correct?
Have you checked that the video drivers are up to date?
Have you checked that the case air vents are clear and not clogged which may cause overheating?
Does it only occur with the one game or all games?
完成的
添加一条评论
1个答案
The first thing to rule out is overheating (CPU, motherboard, hard drive or power supply), then check for bad memory, also test with another power supply.
Only after checking ALL of these would I think it was a Motherboard issue.
Please do keep me updated. Thank you!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
DjDestroyer27 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,008
