跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
Apple bootloop and battery issue
I had an issue with my screen, and apparently seems that’s causing the bootloop. I discovered yesterday that If I press the screen with a little force, the bootloop temporarily disappears and boots normally.
The battery is another issue which I can’t understand, according to apple settings it said that my battery health is 62%, however, if I disconnect it from the charger, it immediately turns off.
What can be causing these issues? Bad cable placing? Need to replace battery ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
If your battery health is at 62% I am amazed it even tries to boot. Replace the battery and it will boot without any problem.
这个答案有帮助吗?
得分 2
添加一条评论
Try downloading a iPhone diagnostic tool on a PC and see if anything shows up. Such as any battery problems, or if you can have the genius bar look at it.
这个答案有帮助吗?
得分 0
添加一条评论
Given the age of the device, I would say that this phone needs a new battery. This may help solve a lot of the issues you are having with the phone.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
noteinstein 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 3
总计 55
