跳转到主内容
加入维修社区 - 创建账户
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
Battery issue? Or something else?
Battery drains which is expected since I’ve had it since 2017, I am going to replace the battery myself but it just started cutting in and out when I try to make a call or even just try to open up certain apps?? What I mean is I can dial the number it rings and I can hear it but the screens goes black so to choose an option on phone I have to hit power button to bring it back up and can’t even opens numbers to opt into flashes off n on. When I try to open up some of my apps it quickly flashes off and on and can’t open app??? What can cause this??? Thank you for your time. Sue c
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It could be that the flickering you've noticed only takes place when you try to open up a single app. If that is true, then the issue is most likely with that app and not the iPhone itself. It might be a minor software problem.
Make sure that your device has the latest version of iOS. Then check for app updates. You might need a Wi-Fi connection to update some apps on your iPhone.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
sue clark 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 82
