跳转到主内容
iPad (第七代) 的維修以及拆卸指南
Deactivated iPad / forgot Password
So i forgot my passcode for my iPad and now its deactivated. It says “connect to iTunes". Usually, when it in DFU mode there sould be an usb cable and the iTunes logo on the screen and iTunes should say that there's a Problem with the device. But on my Display there's the Usb Cable and a laptop logo, and when i put it in DFU while iTunes is opened, the “Your device has a problem…” message wont pop up. Did anyone understand my problem and could help me? Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Dfu is black screen with no image on screen
完成的
添加一条评论
1个答案
DFU mode and recovery mode are different. If you forgot the passcode for your iPad or your iPad is disabled, you can use recovery mode to restore your iPad to its factory settings.
  1. Make sure that your iPad isn’t connect to your laptop.
  2. Power off your iPad.
  3. Connect your iPad to your computer while holding the Home button. Keep holding the Home button until you see the recovery mode screen.
  4. Open iTunes on your laptop. It will pop up a dialog telling “There is a problem with the iPad that requires it to be updated or restored”. Choose the Restore option. iTunes will download software for your iPad. If the download takes more than 15 minutes, your iPad will exit recovery mode and you will need to repeat the above steps to put it back in recovery mode.
  5. Wait for the restoring process to finish. Then you can set up and use your iPad.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nick 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 118
