跳转到主内容
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
873 个问题 查看全部
iPhone 8 in endless bootloop and dies when unplugged
I just got a new screen for my iPhone 8 and it is in a endless bootloop when plugged in and when I unplug it it instantly dies and won’t turn on when I press the power button I plug it back in and same thing. I also tried plugging it into the computer but it won’t do anything .Could this possibly be a bad battery ? I’m trying to transfer data to a iPhone XS
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
Check the battery connector and make sure the pins on the side have not been pushed into the plastic. Also there is a chance you nudged some tiny components around the battery connector. There are a couple of mosfets and a couple of resistors. If these have been nudged or knocked off it would cause the phone to behave as it is.  You will probably need magnification to check as the components are tiny.
这个答案有帮助吗?
得分 2
添加一条评论
Have you ever left the phone unused for more 8 months or so? My only theory is that the battery got discharged so much that there’s not enough power to the phone, and since iOS devices boot up automatically it constantly tries to boot but ends up draining the battery every single time.
You could replace the battery or try to prevent the device from turning on automatically.
这个答案有帮助吗?
得分 0
添加一条评论
Imhaving the same issue with my XS
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ethan hay 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 119
