跳转到主内容
Announced September 9th, 2014, this device is Apple's first foray into smart wearables. iFixit's repair manuals are applicable to Apple Watch (steel) and Apple Watch Sport (aluminum).
210 个问题 查看全部
Apple Watch won’t accept replacement batteries
Greetings,
I have an Apple Watch 7000 series with a swollen battery that I’m trying to replace, but it doesn’t seem to accept any of the replacement batteries that I’ve tried.
I’ve tried about four batteries purchased from both InjuredGadgets and MobileSentrix, but when I install them, the watch enters a loop where it shows the Apple logo, fades to red, and repeats. The kicker is that if I put the original swollen battery back in, it boots up as normal.
I have no idea why this is, but then again I’m no expert, so I would appreciate any insight. Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论:
Technically there is no Apple Watch 7000 series. What you are reading the the Aluminum grade number 7000
Reference: Apple Watch 7000 Series
Can you identify which watch you have. IF you can run it off of the original battery. on the watch go into Settings > General > About - locate the Model heading and then tell us what it is.
完成的
I just checked and it’s an A1553, which I believe would make it the first generation or “series 0” in common internet parlance
完成的
Personally I have had no issues replacing the battery on an iWatch of this model. So it definitely can be done. I know that isn't super helpful but I suppose it narrows out the possibility that Apple would have some sort of serial signature recognition with the battery to ensure only OEM batteries are used or something?
完成的
添加一条评论
1个答案
OK so now we need to make sure you got the correct battery for this A1553 series The original Apple Watch
There is no serialization between the watch and the logic board. There is differences between the different series so getting the wrong battery is the more likely here.
Apple Watch (42 mm, Original & Series 1) Battery图片
产品
$16.99
Apple Watch (38 mm, Original & Series 1) Battery图片
产品
$16.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Janus Henkk 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 3
总计 299
