跳转到主内容
Repair information for Sharp televisions.
105 个问题 查看全部
Sharp tv shows no picture, but indicator light is lit.
I acquired a free 50” TV. IT is a Sharp LC50LE752E. It does not show a picture.
When power is plugged in, the indicator light will turn on, the backlight stays off and nothing is visible, even with a flashlight. When pressing the touch buttons on the tv nothing happens. When pressing buttons on the remote control the indicator light will blink indicating the IRsignal was received, but nothing happens.
Out of the 20 times that I have booted it, it did turn on 3 times and stayed on. It then showed a ‘No Input’ screen with a perfect screen without glitches. After powering it off and on again with the power button, then it would not show a picture anymore.
Troubleshooting:
  • All power supply connector voltages are normal, except there is no backlight_on voltage. Standby power is 5 v
  • Return power from the main board to trigger the power supply board is 3.5v.
  • Manually shorting the Backlight on with the Power supply on lights the backlight normally and will stay on as long as I short it.
  • I have reseated all connectors going between the boards.
  • I have checked all diodes and capacitors on the PS board. All diodes are one-way and all capacitors show acceptable ESR.
  • I have tried to find out why it did boot sometimes, but have not been able to. Have tried pressing on the main chip for example.
The main board is DUNTKG135FM08. The power supply board is RDENCA459WJQZ.
Board diagrams in PDF:
https://1drv.ms/b/s!AkpE6xgs6VHNhGNwakvV...
I am guessing there is a problem with the main chip or the standby chip IC3800. I’m not sure where to go from here. Any help is appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
try turning it on and make sure the room is dark use a torch and go on an angle flash the torch on the screen and see if u can see a faint pic on the screen also can u hear any sound
这个答案有帮助吗?
得分 0
1条评论:
Thank you for your reply. As I mentioned in the initial post the backlight stays off and nothing is visible, even with a flashlight. No sound.
完成的
添加一条评论
添加你的答案
Roy 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 27
总计 858
