跳转到主内容
加入维修社区 - 创建账户
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
Home button won't work.
Good day, fellow repairers. Basically my story began with iCloud lock. Bought a used phone from EBay and I decided to replace motherboard. Didn’t know I had to buy it along with button, so I installed one alone I had. Tried with original button. Input didn’t work as Home Button, neither as Touch iD. Bought Touch iD/Button for it. Replaced old original one with new, knowing that there will be no Touch iD. It didn’t work also, so I decided to bring everything back together, since original Button worked with original Motherboard. After that it just didn’t respond like the one I bought. Why did this happen? Should I get new Motherboard with Button? Thanks in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
The problem is most likely a micro tear in the home button flex from the screen to the logic board. You will need to try another screen.
这个答案有帮助吗?
得分 2
2条评论:
But the screen itself works just fine, it's also a good one and not those cheap ones. Sensor on it also works perfectly.
完成的
However, I'll try today and I think you might be right, wait for kudos once I test it all!
完成的
添加一条评论
添加你的答案
Daniel Malin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 35
