跳转到主内容
Getting error trying to format drive
Hi, what about MacBook Air 11" 2012 where there is no SATA cable?
While doing the partition, it shows error like this;
Partition failed
Partition failed with the error:
Unable to write to the last block of the device.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The drive is a custom blade drive in, I have replaced several of them using drives purchased from OWC with success.
Sometimes the board needs to be resoldered using a reflow system if replacing the drive doesn’t work which is very expensive.
I have occasionally done a ‘botch’ job by removing the board and putting it in a 150c temperature oven on a silicone mat for an hour or so but I don’t recommend it as it is very easy to destroy the board by overheating or warping if it is cooled too quickly
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
cackling 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 127
