跳转到主内容
加入维修社区 - 创建账户
苹果于2019年5月发布的第七代iPod touch。这款型号搭载可达256 GB的存储和A10处理器。型号A2178。
Possible LED Issue Due To Drop
Hello! I have a 7th generation iPod Touch that dropped (while in a case) from about a two and half foot tall counter. The screen immediately started to fade white outwards and then right after started to fade black in towards the middle of the screen. It even has a few dark dots. I wasn’t able to see if it hit a specific corner at the time since it happened so fast but is this problem something I can fix?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Are you able to see the unit when connected to your computer via iTunes? If you are then it sounds like you damaged the display assembly and will need to replace it. Here’s the guide iPod Touch 7th Generation Display Assembly Replacement and here’s one source of the screen iPod Touch 5th / 6th / 7th Gen LCD and Touch Screen Replacement
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kaashi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 168
