跳转到主内容
How to retrieve data?
My 2014 Macbook Air is completely dead and won’t turn on. The Apple store said the problem is likely water damage to the logic board. Is there any way for me to retrieve the data from it? The Apple store recommended using a toaster but I’m not sure which models would be compatible with the hard drive. Any help would be appreciated!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Someone at the Apple Store told you to use a toaster? I wouldn't do that! Heat won't help you here.
If the system was still wet I would take it apart and carefully clean out all of the spill and you would need to likely clean off the parts with distilled water and/or 85% or better isopropyl alcohol
完成的
添加一条评论
1个答案
已选择的解决方案
To recover your data you’ll first need to get a case which can hold it like this one: OWC Envoy Pro Portable, Bus-Powered USB 3.0 Storage Enclosure for select Apple Flash SSDs from most 2013 to 2015 Mac Models
Follow this guide to get the SSD out MacBook Air 11" Early 2014 SSD Replacement
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ally H 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 174
