跳转到主内容
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
Power button not working after replacing keyboard
I have a MacBook Pro 13” Retina Early 2015 that had some damage to the keyboard and the backlight. There were certain keys at the time that weren’t working. Just yesterday I replaced the keyboard and the backlight, and all of the keys appeared to be working.
I noticed that bluetooth was having issues, not showing up in the System Preferences and saying Not Available. I shut down the system from the apple menu to reset the SMC, but it was not working. Then I was unable to turn it back on with the power button. I have to remove the battery connection and then plug it in to power to get it to turn on. Also, when it is powered on, the power button still will not work.
I removed the trackpad cable and tried to power the system on, as I read that could work, but it did not. I am at a loss now. What are some other things I can check or try to make the power button work?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Sounds like your I/O board or the I/O cable needs replacing 交换MacBook Pro13'' Retina显示器 2015早期版本的I/O板 and MacBook Pro 13" Retina (Late 2013-Early 2015) I/O Board Data Cable
Here’s the guide you’ll need to follow: 交换MacBook Pro13'' Retina显示器 2015早期版本的I/O板
Replace an I/O Board Data Cable compatible with the Late 2013 to Early 2015 MacBook Pro 13" Retina laptop. Fix the connection between the I/O Board and the Logic Board.图片
产品
$9.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tyler Worley 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 95
