跳转到主内容
在2017年6月,Apple更新了13寸的MacBookair,他换上了更新更好的Intel Core i5处理器,让性能和电池续航时间提高。
423 个问题 查看全部
Why does my MacBook Air not charge?
Hi there, I have a MacBook Air which is not willing to charge.
The MagSafe 2 charger does not light up - it stays off no matter what. I have tried with multiple different chargers which all yield the same result.
The MacBook Air does not charge, however I can use it as long as I keep the power adapter connected to it.
I tried doing a SMC-reset.
Any suggestions as what to look into?
EDIT - added Coconut Battery screenshot
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see 在已经存在的问题里加入图片
完成的
Hi @danj
I have uploaded a screenshot as per your request. Even though the charger is connected the battery does not charge.
完成的
添加一条评论
2个答案
最有帮助的答案
Ouch! Not good ;-{
Clearly we can see the charging logic on your logic board has failed. A common cause is using knockoff chargers
Don't Replace Your MacBook Charger With a Cheap Knockoff
OEM MagSafe Chargers vs Cheap Imposters: Teardown for Truth
Lacking safety features, cheap MacBook chargers create big sparks
FAKE Magsafe MacBook Chargers on eBay - Watch before buying a Mac Charger
But at this point you will also need to get the logic board fixed or replace it as well. Where do you live? Country and nearest city?
这个答案有帮助吗?
得分 1
2条评论:
Oh man!
Are there any way to test if a new logic board would make a difference?
I live in Demark, Copenhagen.
完成的
@Kasper Jensen - The clue is the 0 Watts and Connected besides the charge state of the battery of 6728 and the health as still quite high at 94%
So that aims us to the logic board charging logic. Sadly we don't have a repair pro listed in Copenhagen, you'll need to ask a few friends and look through web listings for repair shops. They need to be able to do micro-soldering. The other direction is to just replace the logic board on your own is not overly difficult if you feel up to it.
Either way will work!
完成的
添加一条评论
I have a very similar problem, just since my battery is completely depleted I cannot do any sysyem or hardware checks. My first thought is to test the charger with a voltmeter but I am unsure how to do...what pins to test and what I readings I need to see. Any input would be great!
Review these images:
The connector should look clean
MagSafe Pinouts
这个答案有帮助吗?
得分 0
6条评论:
@sufaia - What is the color of your MagSafe LED? Amber or Green?
完成的
Hello Dan,
Thanks for the replj.
I do not get any of the usual lights on the MagSafe.
完成的
Clean the MagSafe connector pins. If doesn’t work you’ll need to replace the I/O board and cable. Review this guide MacBook Air 13" Early 2017 I/O Board Replacement
完成的
Thank you! Can I clean the pins with alcohol or?? Should I test, the MagSafe before digging into the r&r of the I/O board. How might I test the MagSafe? Voltmeter?
完成的
@surfalia - Yes, use Iso alcohol with a cotton swab to clean the surfaces of dirt. Make sure your port looks like the images I posted in your post about.
I use a second known good MagSafe to do my testing. If I suspect the MagSafe as being bad because its in disrepair (cord or pins are damaged or the case has been opened I don't bother in testing it as the MagSafe can damage the MacBook! To add to it I also look for signs the charger is a knockoff:
I only use a REAL Apple unit bought directly from Apple as 90% sold online or non-Apple stores are knockoffs!
Review this Vid for more info on the charging circuit Macbook Air Magsafe charging circuit walkthrough and repair
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Kasper Jensen 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 183
