跳转到主内容
华为2019年4月的旗舰机,搭载6.47寸FHD+OLED屏,屏下指纹,40MP主摄,加8MP远景镜头和全新的耳机扬声器技术,型号VOG_-L29和VOG-L09
phone can’t read sim ... I get NO SERVICE
Hi hello there guys …
I opened my phone back cover ….
for doing testpoint for fixing software thing …
I flashed a few firmware ( ROMS)
for test … in beginning everything was working…
in my last try phone was bricked …
so need to open back cover for testpoint…
it’s took me a week to work with phone till
can fix it to work again…
everything looks good…
but I have no network… no service…
phone doesn’t recognize the sim….
I tried to look if something is no connected…
but it’s all look ok….
I don’t know how? and where to check for fixing the problem??
what should I do?
please help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
4条评论
same here can anyone here help me with my Huawei p30 pro it now not reading sim card
完成的
I have dual sim Huawei p30 pro and sim card works only In one slot.
完成的
I have this same problem I mean no service at all tryed so many sim cards no any worked. So I bought new replacement sim card board changed still not working .. any idea where is antenna or is build up In sim card board? I would buy antenna but can't find any on eBay etc can anyone help me please localizate problem Huawei p30 pro
完成的
Can someone make it work the sim card reader? I have the same problem with a Huawei p30 pro.
完成的
添加一条评论
3个答案
最有帮助的答案
there is a video on u tube showing that sim card cable to motherboard is the fix
这个答案有帮助吗?
得分 1
1条评论:
do you have a link to said video by chance?
完成的
添加一条评论
I don’t know for certain how to fix this, but…standard troubleshooting procedure to help isolate the problem would be:
  1. Have you got the SIM card in the right way, and in snugly?
  2. Have you tried the same SIM card in a different known good phone
这个答案有帮助吗?
得分 0
1条评论:
Hi hello there my friend
the answer is yes … for 1…
and yes for 2
I use this sim everyday … also tried other 3 SIM cards ….
still no service…
hope can find good advice… have a good day…
完成的
添加一条评论
I have the same problem. I've tried antenna replacement, sim reader replacement, pcb flex replacement. I have not tried a new charging/ main board flex this is my next theory to try (waiting on part delivery). If main board flex does not fix my next theory is that the main flex connector on motherboard might be "loose", customer had damaged original screen in the same area as main board connector. Would need to resolder or replace and solder main board flex connector. If that is not successful I may have to replace band width ic chip. Note I've also tried going back to earlier software version, did not work on previous software versions.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Yuri 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 32
总计 3,952
