CPU fan shutting down randomly
New build pc- never built one before
ryzen 7 3700x
stock wraith prism cooler
msi mpg x570 gaming edge wifi
2x8gb ddr4 3200mhz Corsair vengeance rgb pro
gigabyte windforce oc RTX 2070 super
wd black 500gb nvme m.2
wd velociraptor 500gb ssd
gamemax rgb mesh case
seasonic focus 750w psu
everything seems to be working perfectly, all temps are normal not sure what else to look for, it plays fine, but every so often the cpu fan and rgb and the case fans and rgb stop and go dark but the pc is still on and the ram still lights up. If I press the power button again they all kick back in and start up again.
ive checked the psu connections and the motherboard screws and the motherboard connections, I don’t know what can be causing. It
thanks
2条评论
Hi
Have you got the latest BIOS firmware installed and possibly the latest chipset drivers etc?
Just a thought.
由 jayeff 完成的
I’m not sure, how do I check? I’m not very techy I just wanted to make my son happy by building a pc with him
由 gias_girl 完成的
