跳转到主内容
1.86GHz or 2.13GHz Processor, 128GB or 256GB Flash Storage
147 个问题 查看全部
upgrading logicboard from 1.86 GHz 2GB to a 4GB
I have a late 2010 MacBook Air 13” 1.86GHz 2GB RAM 128GB Flash Storage. Running OS 10.9.3 (13D65).
Would it be possible to upgrade it to the 1.86GHz 4GB RAM logic board?
Would I have to reinstall the OS if i replace the logic board?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Sure you can swap out your logic board with 4 GB of RAM
  • 13” MacBook Air Logic board, 1.86GHz, 4GB: Apple P/N 661-5798 - Aprox $180 USD
  • 13” MacBook Air Logic board, 2.13GHz, 4GB: Apple P/N 661-5734 - Aprox $200 USD
Here’s the guide MacBook Air 13" Late 2010 Logic Board Replacement
The OS is on the SSD drive which you’ll transfer to the replacement logic board so you won’t loose anything or need to re-install your OS.
But with what I’ve said here I don’t think this makes much sense given the age of the system and the cost as well as availability of the part. I would strongly recommend looking for a newer used MacBook Air or Pro system as being a smarter investment.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
jess ralphton 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 52
