跳转到主内容
The Galaxy S7 Edge is the curved-screen variant of Samsung's 2016 flagship phone, the Galaxy S7. Announced February 2016 and released on March 11. Model SM-G935.
369 个问题 查看全部
No network signal antenna repair
So I get very poor network and data (4G) signal on my S7 edge. I read somewhere to replace wifi antenna, but after further research I’m not so sure. The phone connects to wifi with no issues, and now I see there are two separate antennas, top and bottom, which are above and below the charging coil. Upon taking it apart I see the wifi flex antenna cables are under the motherboard, and to replace them also requires a screen replacement, and that there is no visible damage to the cables or their connections.
My question is which parts do I need to replace to get back normal data and network signal? Is it the top or bottom antenna, or both? Any helpful replies are welcome, would be very grateful if you could include pictures. Thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Signal issues may not always be related to the hardware in the phone. Do you get poor signal wherever you are or in specific areas? If it’s only in specific areas then it’s most likely an issue on the carrier’s end which can really only be addressed by them or by switching to another carrier. For example my ex had TMobile and at the time, I was on AT&T. At her mom’s house I would be lucky to even get a signal at all. At her dad’s I get a slightly better signal but not much. Then I switched to Verizon. I got fantastic signal at her mom’s but almost nothing at her dad’s.
If it’s a consistently a bad signal wherever you go then it could be an issue with the phone. You could try replacing the two antenna cables towards the bottom of the phone along with the charge port. Also make sure it has all of the black shields on the back.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
sublimerule 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 786
