跳转到主内容
The Kushlan Cement Mixer 1000DD-WB is a direct drive cement mixer with a 1.5-horsepower direct-drive motor. The mixer's polyethylene drum can hold up to 10 cubic feet or about 800 pounds of wet cement.
1 个问题 查看全部
How to remove motor and gearbox from barrel?
1000ddwd kushlan mixer. Replacement gearbox received. Can't get the old box off the barrel. Have already removed the giant bolt in the spindle that should have freed the whole assembly. Do I have to tear this thing down to the nuts?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi,
Don’t know if this helps or not but here are the gear motor assembly instructions section of the user manual.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Rob Turner 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 20
总计 470
