跳转到主内容
2017年9月22日发售。型号有A1864,和A1897,可选GSM 和 CDMA 网络,存储有64GB和256GB,颜色有金色、银色和深空灰色。
678 个问题 查看全部
Why has my reception been bad since I replaced the rear housing?
I recently replaced the rear housing of my iphone 8 plus and I now have really bad reception compared to other iphone 8 pluses on the same carrier. I broke the top antenna flex cable but have now replaced that but still have bad reception. Is the antenna itself located in the rear housing and would that be why I don’t have as good reception? - (when i say reception i only mean cellular reception, wifi has been absolutely fine)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
I had a look and one of the bracket connectors had snapped, so I replaced that and it’s working beautifully
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
Is the housing original or aftermarket? Some aftermarket housings may not have proper connections to use the housing as an antenna.
I’ve read in some posts that adding a bit of solder on the connection points on the housing may solve the problem. Correct me if I’m wrong.
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
Oliver Davies 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 81
