跳转到主内容
Apple的9月20日发布的Apple主流2019 iPhone带有6.1英寸LCD触摸屏,双摄像头和六种可用颜色。iPhoneXR的后继产品。
475 个问题 查看全部
Did I break face ID?
Customer came in with an iphone 11 screen that was cracked topside and in restore mode. There was a lot of dirt/dust/etc on 1 of the selfie cameras and dot projector. I replaced the screen and updated the iOS and the phone worked. I tested face ID but it wouldn’t let me set it up. It says that I have to try again later or that my face is out of view and I need to reposition it. Portrait mode says I need to move further away. Proximity sensor and auto brightness works when I tested calling someone. I called the customer and asked if face ID worked and she said yes what I don’t really believe. If I am correct the dot projector is broken, but I did not remove the selfie cam.
Is it possible that unlocking works but setting up a new face ID fails or if it’s broken, nothing will work.
I have replaced a lot of iPhones with faceID and have never broken one before. Is this the first time?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Can you post pictures of the device and potentially damaged components? I have a policy in my store for situations like this. I perform a functionality test before any repairs are attempted. If I can’t test everything, I’m not liable for those components because although the customer claims those parts were working when it came in, I don’t 100% know that and unfortunately you can’t take everyone’s word for it. Sounds like you should have a similar policy in place. If it says to move around, you may just need to adjust the front selfie camera assembly a little bit and make sure the sensors are seated properly as well. And why was it in restore mode?
这个答案有帮助吗?
得分 0
1条评论:
The parts all look fine, but it is an insurance claim so we are adding the face ID to the list. Thanks for the suggestions
完成的
添加一条评论
添加你的答案
KWH 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 145
