跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1233 个问题 查看全部
iPhone headphone jack not working after drop
I dropped my phone today, and cracked the screen. I can just order a new screen online. I also noticed that my headphone jack stopped working. After taking a look inside, it was really dirty, and I pulled a crap ton of dust out of it. Now my earbuds satisfyingly insert into the jack again, but the port still doesn’t work. I tried the earbuds in other things and they worked fine too. I tried rebooting a couple times, but my phone still won’t recognize when they’re inserted. Are there any other possible things that could have gone wrong?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
The connections of the jack may be disconnect to the motherboard of the mobile. Check them
这个答案有帮助吗?
得分 0
2条评论:
I'll check them tomorrow. Thank you, I'll let you know if this worked out.
完成的
If I'm not mistaken, the cable you meant was the one next to the battery? I tried removing it and reconnecting it, and it still isn't working.
完成的
添加一条评论
HOOOMYGOOOD!! I legit have this same problem. After dropping my phone the earphones don’t work. I plug them into anything else and they work so it’s not the earphones that’s the problem. My mic doesn’t work either. It only works if I have Bluetooth earphones connected to the phone … weird.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Declan Moore 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 6
总计 391
