跳转到主内容
Samsung的旗舰手机,Galaxy S8,发布于2017年4月。
304 个问题 查看全部
Screen darkened and only keyboard showing.
Hello!
I woke up this morning to find my phone refusing to work. Upon lighting up, the screen is stuck with a bright white/yellow block where the keyboard should be, with faint keyboard markings. The rest of the screen is very dim and can’t really be seen around it. Have tried restarting it several times but i can’t open the lockscreen or access the phone due to the keyboard block. Screen is not cracked or broken either.
(sorry for terrible image quality. had to use an old webcam for the photo)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Can you post an image of the phone showing the yellow / black block on the bottom of the screen? I suspect the screen display is failing.
在已经存在的问题里加入图片
这个答案有帮助吗?
得分 2
6条评论:
added for you!
完成的
Try booting the device into safe mode and see if the problem still persists. If not there is a application that is most likely causing the problem and you'll need to either disable it or uninstall it.
How to boot into safe mode here:
https://www.samsung.com/au/support/mobil...
完成的
thank you! i'm unable to get past the lockscreen to be able to shut the phone down properly, as the keyboard is blocking me from doing anything. Have tried connecting to my PC to no avail as the screen needs to be unlocked for me to access files.
完成的
You can hold the power + volume down + bixby button for about 5-10 seconds to force the phone to shut off. Then you can power the phone on again after doing so.
完成的
After doing this, it prompted me to accept an install of a custom OS? is this normal?
完成的
显示更多的1条评论
添加一条评论
添加你的答案
caitlin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 8
总计 409
