跳转到主内容
Device and repair information for the 60" LED HD TV by Samsung released in 2013, model number UN60FH6003FXZA.
203 个问题 查看全部
Why is there a black vertical line on screen?
The actual device is a 60” 2013 LED Smart TV (F6350 Series) UN40F6350AFXZA
A thin verticle black line has recently appeared on my tv screen.
I ran 3 screen test and it failed all of them.
How do I fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@livenlearn … this is a failed tab driver for your panel. it is either a loose connection or on its way out. you could try and take the bezel off and gain access to the tab it corresponds with in that section. gently apply pressure to the tab and see if the line dissipates. if so, you can wedge some soft foam and re assemble the set. at some point, its going to fail completely. if its under warranty, act now. if not, prepare yourself for a new set down the line.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Ang 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 150
