跳转到主内容
在2017年6月,Apple更新了13寸的MacBookair,他换上了更新更好的Intel Core i5处理器,让性能和电池续航时间提高。
Issues creating bootable disk of Sierra
I am having an issue creating a bootable disk of Sierra. I am trying to make the bootable disk on a 2017 MacBook Air running Catalina. I have downloaded Sierra and created the installer in my applications. The bootable disk is for an older computer I am trying to restore. I have tried Install Disk Creator and it gave me the error that it couldn’t dismount my USB to erase it. The USB is a 3.0 with 64 GB. I have formatted the USB with Mac OS Extended (Journaled) and GUID Partition Map. I tried Diskmaker X and it failed as well. I then tried the Terminal route with the following:
sudo /Applications/Install\ macOS\ Sierra.app/Contents/Resources/createinstallmedia --volume /Volumes/Untitled --applicationpath /Applications/Install\ macOS\ Sierra.app
I got the following response:
2020-08-19 14:58:41.822 createinstallmedia[8986:81124] *** Terminating app due to uncaught exception 'NSInternalInconsistencyException', reason: 'Couldn't posix_spawn: error 35'
  • First throw call stack:
0   CoreFoundation                      0x00007fff36a37b57 __exceptionPreprocess + 250
1   libobjc.A.dylib                     0x00007fff6f87e5bf objc_exception_throw + 48
2   Foundation                          0x00007fff390faf01 -[NSConcreteTask launchWithDictionary:error:] + 4993
3   Foundation                          0x00007fff391247f1 +[NSTask launchedTaskWithLaunchPath:arguments:] + 146
4   createinstallmedia                  0x0000000103b33968 createinstallmedia + 6504
5   libdyld.dylib                       0x00007fff70a26cc9 start + 1
libc++abi.dylib: terminating with uncaught exception of type NSException
Any help would be greatly appreciated. Thank you!
I have tried everything I can think of and it still won’t make a startup disk. Here are all the steps I took with their results. I have also added a picture of what I think you were looking for in disk utility.
I thank you so much for your help. This is frustrating considering I just spent quite a bit of money redoing an old computer with a new HD, Ram and battery, and now I can’t create a startup disk.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
5条评论
Lets see a screenshoot of Disk Utility of the drive expand all of the sections 在已经存在的问题里加入图片
完成的
I added the picture. Thanks Dan!
完成的
I was hoping to see both the partition map (GUID) but also the HFS+ or APFS file system info as well. You want HFS+ here.
完成的
I added pictures showing my options for formatting. There is no HFA+ available. Is there a way to make it available?
完成的
@spydergs1 - I guess I should have been clearer.
You keep opening up the modifier window. Showing me the format action in the first & second pics so its not done yet.
All I needed to see is what's hidden behind it, when you pick the levels within the left column. So as an example my MacBook Pro has a Samsung SSD and clicking on it the right window shows: 'SATA Internal Physical Disk • GUID Partition Map'
If I click on the drive volume held inside you'll see 'Physical Volume • Mac OS Extended (Journaled)'
完成的
添加一条评论
1个答案
最有帮助的答案
So let’s do this, after formatting the disk (which appear to have done properly).
Download this file from Apple How to upgrade to macOS Sierra jump down to Step 4 and click on the Blue URL link labeled ‘Download macOS Sierra’ You’ll need to double click on it to unpack it. Take the unpacked dmg file placing a copy onto your Thumb drive.
Review this guide How to create a bootable macOS Sierra installer drive to convert the file into a bootable image.
That should do it!
Now take the thumb drive placed in your other system and then see if it starts up under it. If not restart the system again this time press the Option (⌥) key to get to the Startup Manager then select via the arrow keys.
Reference: Mac startup key combinations
这个答案有帮助吗?
得分 1
2条评论:
I did what you said and it still didn't work. I added pictures to my initial comment. I can't figure out what I am doing wrong. Thanks for your help.
完成的
@spydergs1 - Just double click on the USB Installer file to start the install process.
完成的
添加一条评论
添加你的答案
spydergs1 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 917
