跳转到主内容
发布于2015年3月,并在2015年4月10日上市。盖乐世S6是盖乐世家族又一部旗舰机型。其曲面屏版本被称为盖乐世S6 Edge。
486 个问题 查看全部
Samsung S6 won’t turn on only showing (white led)
I’ve tried most key combos. I’m going to take this explanation from DroidGuy because it matches my exact problem. “I have a Samsung Galaxy S6. I had it hooked up to the charger all night, woke up the next morning, saw that the battery icon was full and green. When I went to turn it on, the whole screen went black and I have not been able to get it running again since. I tried all the troubleshooting there is, still nothing. The only thing that happened is a solid white LED light.“ The phone has a lot of sentimental value to me and it’s not an option to take to the store help?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
you fix this? i have the same problem
完成的
I’ve just found my old Galaxy again which has this exact problem. Still no way to fix this?
完成的
添加一条评论
5个答案
最有帮助的答案
I have this problem on the s6 edge+. phone boots up and after a minute it freezes and then shuts down or restarts with the white led on. Cannot use it for more than a minute unless i constantly engage the digitiser(by drawing a 0 on the screen or in a pencil erasing motion). So i’m guessing this issue could be a display shorting or something related to the display connector.
这个答案有帮助吗?
得分 1
添加一条评论
try using another charger or if that doesnt work do a master reset usually when u gimet the white light its a sign battery is dead
这个答案有帮助吗?
得分 0
1条评论:
Hi... I have the same issue ... but in desperation I banged it a little then it worked for few hours and now it’s back to the white solid light ... I tried the same trick again and it is just stuck at the Samsung boot up screen. Frustrated ... wonder if someone can help please as I also have a lot of memories saved up in that phone and I don’t want to completely erase it until I have the memories backed up. Any help please ?
完成的
添加一条评论
After you turn on the phone, you don't need to do anything. After a period of time, the device may be able to boot normally. This is one method I have tried.
这个答案有帮助吗?
得分 0
添加一条评论
It happened to me now and it happened previously. Just wait for the charging to end and then it will open
这个答案有帮助吗?
得分 0
1条评论:
sorry what do you mean, charge it fully then it will turn on? thanks
完成的
添加一条评论
This problem is related to a hardware issue.
Could range anything from NAND/UFS failure or issues with the RAM or anything.
Samsung hasn't documented anything on this.
I'm still working out what it could mean.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Fix S6 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 38
过去 30 天: 214
总计 7,921
