跳转到主内容
加入维修社区 - 创建账户
2.3L 4cyl or 3.0L V6, 6th Generation
Engine won't turn over or crank but lights, radio, etc come on
I'm pretty sure I've narrowed it down to the starter has gone out. When I turn key all dash lights, radio, etc come on. Headlights, interior lights come on anytime. I can hear fuel pump noise, no clicking sounds from ignition…
I'm certainly not a mechanic AT ALL, though I have a decent idea as to how most of it works, more or less.
I've researched online and weeded out battery,alternator, and ignition switch.
What really makes me think it's the starter is that the wires going from the starter have apparently caught fire at some point, because the black wires around the colored wires are charred and leave black soot on your finger.
Is it possible the starter got too hot and caught the wiring on fire??
Could it be the wiring itself and the starter is still good??
2001 Honda Accord coupe 2.1L manual transmission
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Not a fix but sometimes when your starter is going bad and you get no response when turning the key you can get it to work by tapping it with a hammer. If it clicks or turns over then u need a new starter. If nothing happens then more troubleshooting is needed. Have one person tap the side of the starter with a hammer. Don’t smash it just give it a few firm taps. Have another person try to start the car while it’s being tapped on. Like I said this isn’t a fix. It’s just a low tech way to troubleshoot your starter while it is still mounted to the engine. Also if it caught fire at some point or got hot and melted the wires then that means the starter got overheated from trying to crank for too long or it could be a sign of it straining when it’s going bad. Just be sure to check all the wires attached to the starter to make sure they’re still good and swap them out if not. Good luck.
这个答案有帮助吗?
得分 1
3条评论:
Thank you @ragincajun!
I had a friend come out to the car and try tapping while I turned the key, unfortunately nothing happened.
However, VERY good info to know in the future! I never would've thought to do that!
I guess I need to get a voltmeter to see if the actual starter is getting power will the car is off, but I have a pretty good feeling it won't shower any power going to it.
Really, I just want to know if it is actually possible for the starter to be going bad to the point that it catches the wires on fire!
Any info?
Thanks again for your response!!!
完成的
No problem I hope u figure it out and when I have a minute I’ll throw a few more ideas your way
Good luck
Oh and it might be a good idea to go back and unmark my answer as chosen solution bc u might not get anymore responses if it shows that the question has been answered and the problem solved
Have a good day!
完成的
Thanks! Clearly I am new to this forum, well any forum honestly. Lol.
Thanks again for the help!
完成的
添加一条评论
添加你的答案
Anna Rich 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 16
过去 30 天: 39
总计 8,264
