跳转到主内容
加入维修社区 - 创建账户
丰田于 2001 年 9 月发布了 2002-2006 年款的 Camry XV30 系列,将其作为一款体型更大的轿车。
I have a 2003 Toyota Camry v6 that won't start.
It used to die on me ever so often so I replaced the battery. Drove good for a bit and the same thing started happening. If I jumped the car it would start right up until the other day. I've now changed the starter and the entire ignition switch, ignition housing and ignition but it just clicks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Did you find the problem. I have the same car with same problem. Please let me know
misselle512@gmail.com
完成的
添加一条评论
1个答案
已选择的解决方案
Have you checked the see if the alternator is charging. If you put in a new battery and it runs for a few days and the same thing happens again it sounds like the alternator is not charging. You should learn to find out what is wrong before you just start throwing parts at it. You could probably had it repaired for less money if you had taken it to a shop and had them do it or had them at least find out what is wrong with it before they spent at least a couple hundred dollars.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Llbriggs04 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 554
