跳转到主内容
发布于2018年10月26日。型号A1984,A2105,A2106,A2108。 提供GSM或CDMA / eSIM,nano-SIM或双SIM / 64,128或256 GB /黑色,白色,蓝色,黄色,珊瑚色或红色。 (发音为“iPhone 10 R”)
468 个问题 查看全部
Apple Pay not working on iPhone XR
I swapped a screen and housing on a XR and now Apple Pay isn’t working.
All of the small parts were transferred over, but part of the charging coil tore so that had to be replaced. The coil and the screen are the only new parts.
Which part of the phone makes Apple Pay work, and why would it not be working? Thanks in advance for any insight!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
You can do one thing that you can update the Apple Pay by which it can work
这个答案有帮助吗?
得分 0
1条评论:
Thank you for replying. What do you mean by update the Apple Pay? Delete the card and re-add it?
完成的
添加一条评论
Hi I have the same problem, have you found out what has caused it and how to fix it.
这个答案有帮助吗?
得分 0
4条评论:
I have also heard that the nfc might be located between the metal and glass of the back housing so I don't know if changing the housing to a third party housing may have caused it
完成的
Hey Colin! I ended up taking it apart again to add a new charge coil (which supposedly has the NFC as well). But didn't end up replacing the coil, as it arrived incomplete.
Anyway, when I reassembled everything, the Apple Pay ended up working.
I think the NFC antenna is associated with the cable from the charge coil that connects to the left frame of the phone, if that makes sense.
Are you doing a repair, or did Apple Pay just stop working?
完成的
Yeah I was doing a housing replacement and the coil was broken, how hard is it to replace the coil I understand it requires micro soldering which I haven't done before but can learn
完成的
I would think it's easier to just replace the whole coil. Just make sure the coil already has the connector attached.
完成的
添加一条评论
添加你的答案
Erika Cuellar 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 12
总计 1,381
