跳转到主内容
The Xbox One Wireless Controller model 1697 was released in 2015 and replaced the model 1537 controller and fixed some of the problems found on Model 1537 controllers. The Model 1697 controller includes an integrated 3.5mm headset jack, which allows compatibility with most 3rd party headsets without the need of an adapter. This controller has been discontinued and replaced by the Model 1708 controller.
75 个问题 查看全部
Can a loose aux port affect your headset mic?
I recently replaced the headphone jack on my controller as it had issues, the new one works except the mic on my headset won’t work at all. I know the headset is fine as it works perfectly on my laptop, could it be a loose connection somewhere or should i consider a new controller?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
I figured out the problem, i just had to gently bend the connection pins on the aux port out slightly and it works perfectly now
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
Yes, a loose connection can cause problems with microphone connectivity. Check your connections, and maybe try a different set of headphones (if you haven’t tried already)
Make sure that the jack has 4 pins, not three, and that the headset also has 4 pins. (Google “4 pin headphone plug” if you’re unsure)
这个答案有帮助吗?
得分 1
1条评论:
thank you for the help
完成的
添加一条评论
添加你的答案
Harlan Nohava 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 7
总计 1,196
