跳转到主内容
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
LCD power connector problem? And how to fix It
Hi,
my screen fell of, and it snaps a little bit power connector on Logic board, one of the pins is loose, and backlight on screen does not work (computer works fine when plugged to external monitor, also on built in screen after turning iMac It is possible to see Apple logo.
How can i fix It ? I want to solder pin back, but what voltage should i see on this pins ? Anyone has graph for that ?
Update (08/17/2020)
@danj Thanks Man,
I’ve soldered pin right to its place but, screen still does not have backlight .
I’ve check continuity on pins and they looks ok, two pins on left have same connection to the chip below is this correct ?
I want to make sure that Logic board is fine before ordering a new screen :)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
@danj thans for the tip :)
does anyone have information about voltages i should see on this pins ?
完成的
Sorry I don't have the schematics for this series. I would just test continuity across the connector pin by pin.
完成的
添加一条评论
1个答案
Be very careful! Push the pin back through the plastic go slow and make sure you don’t over stress things!
Once the pin is at the same elevation as the other pins, carefully solder the pin back down, hopefully the pad is still present.
Before you push the cable back on make sure the pin is inline with the others.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Raf 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 129
