跳转到主内容
MacBook家族于2006年5月发布,替换了iBook来作为苹果消费级笔记本的产品线。
3787 个问题 查看全部
Is there no inverter cable?
I have this Early 2009 Macook 2.0Ghz Core 2 Duo. I bought it with this problem where the backlight goes off at about 45 degrees and comes back on somewhere at the 120degree angle. I tried to look for parts but I cant find any inverter cables. I know these sometimes break internally and it has happened with one of my older ones, which I did replaced. I cant find the same part for this laptop when I researched it on Ifixit. Does this not have the same cable that the older ones had?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Yes there is an inverter cable for the early 2009 MacBook. It takes the same one that the MacBooks late 2007 Santa Rosa - early 2008 Penryn use ( 3 wall connector on the board). Ifixit does not have any in stock at the moment. Here is a link verifying that the early 2009 MacBook takes the same cable I mentioned. Here is a google shopping search for the part.
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
Zahan 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 5
总计 790
