跳转到主内容
加入维修社区 - 创建账户
谷歌第三代 Pixel,是谷歌首款"刘海屏"手机。配备了一块 6.3英寸 QHD+ OLED 显示屏,内存有64 和 128 GB可选。三款配色分别是(差不多)白,(就那么)黑,(不算太)粉。
Mic doesn't work after charging port replacement
I replaced my charging port with an iFixit replacement. After putting back together everything works as expected except for the mic when not on speaker phone. From my research, the mic is part of the charging assembly. I am wondering if I received a defective part? I am going to take apart again in check all connections. I’m wondering if anyone else has suggestions…
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
3条评论
Hi. what was the solution for your problem ? have exactly the same problems…..
完成的
I did another charging port change and the mic works fine now. It's likely the board I received was defective since the connector seemed seated fine for the faulty board. I was able to perform an exchange to receive a new board. After installing the new board, everything works fine now
完成的
Ok thanks. I think i have the same problem. Ordered new board to test it.
完成的
添加一条评论
2个答案
最有帮助的答案
I would imagine it’s defective. Disassemble and check the connection. Sometimes if it’s not seated all the way it won’t work.
这个答案有帮助吗?
得分 1
1条评论:
I replaced the charging port with a new replacement and the mic now works. I can confirm that the part I used previously was simply defective.
Thanks for the suggestion
完成的
添加一条评论
Getting another replacement daughter board should fix the problem because some replacement board has faulty mic from factory.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
SEAN BEAUSOLEIL 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 769
