跳转到主内容
The Nokia 7.1 Android smartphone was released by HMD Global, a Finnish mobile phone company, under the Nokia brand. The 7.1 was released in October 2018 and is an upgraded version of the Nokia 7.
5 个问题 查看全部
Nokia 7.1 charging port failure
How do I fix a faulty charging port? This is not a cord issue. I bought new cords and they work with another phone. The faulty port appears to be a documented equipment manufacturing issue with Nokia. I have to angle the cord’s USB connector just right into the phone port to get it to charge. To keep the connector in that critical position, I have to firmly secure the plugged phone between a wall and a weight. It is very touchy and the bending eventually destroys the usb connector on the cord. The problem is getting worse and today I cannot get it to start charging at all despite trying all positions and cords. I fear it will go dead. I tried contacting Nokia and I think they won’t take responsibility for this defect and the phone is less than 1.5 years old.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
3个答案
最有帮助的答案
Hi @denmar1 ,
Here’s a video that shows how to replace the charge port - example only in the phone.
Replacements are available online. Just search for Nokia 7.1. charge port to get results for suppliers that suit you.
If doing this yourself seems too daunting, contact a reputable, professional mobile phone repair service and ask for a quote.
这个答案有帮助吗?
得分 1
添加一条评论
Had same issue, eventually plucked up courage to buy replacement charge port and a heat gun.
15 minute job, all good.
58 years old, watch a couple of Youtube demos and dive in, turn off phone, remove sim/sdcard before applying heat!
这个答案有帮助吗?
得分 1
1条评论:
Could you recommend a good site to buy it? Thks
完成的
添加一条评论
I have the same problem,its USB-C module.
It needs to be replaced.Here in Europe many places can do it for ~50 +
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Den 将永远感激不已
浏览统计数据:
过去 24 小时: 8
过去 7 天: 27
过去 30 天: 118
总计 6,704
