跳转到主内容
加入维修社区 - 创建账户
Apple 在 2019 年 3 月 更新了他们的 iPad Air 平板电脑,配备了 A12 仿生处理器和一块 10.5" 屏幕。
Screen White Pressure Point
Ive been seeing this white spot on my screen, and the reps at Best Buy said it was a pressure point on the screen. I tried using a small vacuum pump to try and pull the screen back up from that spot, but it hasn’t fixed it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Best Buy Geek Squad really doesn’t know much about repair other than selling a solution. That white spot could be a couple things like a pressure point if the frame was bent or the battery swelling, although that doesn’t seem likely as that tablet came out just last year. It could also be a defective LCD.
这个答案有帮助吗?
得分 0
2条评论:
Any thoughts on how I could possibly fix it? Everything else works fine. Just that the spot itself is right there in my line of sight and what I’ve tried so far doesn’t work
完成的
@ibsinrg you'll have to take it apart to find out what's wrong with it before you can fix it. I would start by taking the screen off but be very careful. The glass is fused to the LCD, so if you damage the glass or LCD, you'll need to buy a whole new screen assembly. Follow the ifixit guides to take it apart.
完成的
添加一条评论
添加你的答案
Russell 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 33
总计 1,428
