跳转到主内容
The HP Officejet 4620 is an all-in-one color printer, meaning it can print, scan, copy, and fax.
How to replace spring tentioner s HP 4620
How do I replace spring tentioner s on the back inside of my HP 4620 printer
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
此回答最初是针对另一个问题
Hi,
Not sure which springs you’re referring to, but here’s a teardown video of the printer.
At 2:58 minutes into the video the two printhead tension springs are seen being removed by using a tool with a hook
At 7:36 minutes, one carriage unit spring clip is being removed. There may be one on the other end of the carriage.
At 11.57 minutes the feed roller spring is shown.
Hopefully this will help you to replace the springs.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Michelle Speegle Hayes 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 228
