跳转到主内容
The Toshiba 40PB200 is a 40-inch flatscreen television in the PB200 series. It was released in 2012.
36 个问题 查看全部
Toshiba LED TV no red light, only panel light
My 2 year old nephew accidentally launched his wheel toy at our Toshiba LED TV which is only 5 months since its repair.
Now the red light and green light is gone, I don't know if the LCD is okay as there are no lines indicating a broken lcd. If I plug the TV it will light up a bit, and the panel light stays on but no picture or blue screen coming up the display.
So this is already plugged in, but no red/green light:
When I plug the tv on, this screen shows up for a second:
Afterwards, I can see this faint light which I assume is the panel lights. I angled the photos so that my phone’s cam can capture what I see.
Please help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @pstch ,
Presumably there is no audio either?
Disconnect the power from the TV and remove the back cover and check for any damage along the bottom edge of the LCD panel and also on the boards i.e. burnt out components etc.
I don’t know Toshiba but it may be that there are ribbon cable connections there that connect from the board to the panel. Post some images back here of anything suspect.
Not trying to alarm but no audio would also indicate a mainboard problem. What internal damage has happened would need to be assessed first, otherwise it is just guesswork.
Be safety aware, there is exposed lethal AC voltage in the back of a TV when the power is connected. Always disconnect the power before working in the back of a TV unless testing and you know what you’re doing.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
San 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 224
