跳转到主内容
加入维修社区 - 创建账户
An SSD, or Solid State Drive, is a type of storage device that uses NAND-based flash memory to store data.
Not able to unscrew the M2 SSD Card
I am unable to un-screw the SSD M2 from my lenovo laptop. I do have the IFIXIT tool with all the precision but none of the screwdriver bits seems to be working. Please help me with this.
Please find attached the pic of the SSD
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Looks like you stripped the screw. get a fine tipped bit drill, and drill out the screw, and the SSD should come out.
这个答案有帮助吗?
得分 3
3条评论:
Sorry, new to the laptop DIY, do you mean the IFIX Tools will not help? What do you mean by fine tipped bit drill?Thanks for the quick response.
完成的
Once the head is damaged its mostly a matter of finding other options as no standard bit is going to work.
You'll want to try a left hand drill bit which will help in easing out the screw.
I've had luck with a slot cutting file creating a slot down the middle of the screw so a straight bit can grasp the walls of the slot. Make sure you tape off the area so the fine metal particles don't short out anything.
The other possibility is use a line-mans plier which has a flat end straight down grasping the sides of the screw. You do need to be careful as you don't want the plier to damage the board or pop off any components on the SSD.
完成的
Thanks Dan. This is a brand new laptop just got it 6 months back. I do not want to slot cut or use plier since that might impact the SSD. I was thinking a simple screwdriver would do. If not, then I will reach out to best buy/office depot for help. Thanks again !!!
完成的
添加一条评论
I have managed to unscrew it with smooth pliers (without sawtooth on them), even without rubber band.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
HARISHA SUBRAMANYA 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 17
过去 30 天: 85
总计 4,092
