跳转到主内容
The DeLonghi ESAM family of products is a line of automatic coffee machines for making lattes, cappuccinos, espressos, and other drinks. Look for the model number ESAMxxxx on a sticker on the back or bottom of the device.
23 个问题 查看全部
Delonghi Perfecta ESAM 5400 Steam or Hot water not being produced
(the loose connection was me taking it apart)
The hot water steam function is not currently working and I am suspicious of the solenoid. All the hoses are free of blockages and look clean. Hot water comes out of the “in” hose if I unclip it but nothing comes out of the “out” hose side of the solenoid if i unclip that hose (once i’ve reconnected the “in”!). Does it sound likely that the solenoid is the issue? Is there a way to test without ordering a replacement?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
I have an ECAM model with the same valve and same problem. Remove the valve, remove the solenoid by removing the top nut, remove the solenoid actuator the rinse out any material blocking the valve base. That was my problem. If the solenoid coil is no longer working they can be readily bought online.
这个答案有帮助吗?
得分 0
添加一条评论
Thanks Geoff, i forgot to return to this post after fixing it but it was indeed the solenoid coil. Easy fix in the end
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Maxwell Hill 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 30
总计 842
