跳转到主内容
Guides for the LTE version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, originally known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
62 个问题 查看全部
Upper left corner unresponsive most of the ti after panel replacement
Hi everyone!
I exhanged the shattered panel with the guide on this site and it went pretty well. The Ipad seems to work well except for one thing. The glued strips that came with the new panel don’t hold very well and I already ordered new strips.
But what’s really irritating is that the upper left corner is unresponsive most of the time. I have to press down on the lower right corner that won’t stay in properly to make it work. Any ideas what is going on? Should I be concerned? Or will this go away once the panel is glued in properly?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It could be a defective panel or the connector isn’t seated properly or it could have been damaged. You can inspect them when you replace the screen adhesive.
Pro tip: use acetone and Q-tips to remove the old adhesive from the metal frame of the iPad ( not the screen!) for better adhesion. Make sure you do it in a ventilated area or have a fan nearby as you can get a little light headed. Soak the Q-tip in acetone, don’t apply acetone directly to the frame and be careful around plastic parts. Also use some heat and either some weight or clamps to adhere the screen.
这个答案有帮助吗?
得分 0
3条评论:
I'll check this when the adhesive arrives. I hope it's something that's fixable without taking everything apart again. I'm not sure I could do it again.
I did what you suggested but used isopropyl alcohol as I was worried about the plastic parts. Worked decently but I still had to use my fingernails to gently peel off the remainder. I inspected the frame before I put the panel on with a magnifying glass. The comments underneath the guide suggested to make sure that there were no glass shards left.
完成的
@Nina it sounds like it should be a quick and easy fix. I know a lot of suppliers have been having quality issues lately because of the virus.
完成的
@hootonberg You're giving me hope!
I bought the parts before the that from a reputable seller so I hope it's just the adhesive strips. I only had time to do it now.
完成的
添加一条评论
添加你的答案
Nina 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 26
