The laptop turns on automatically once the lid is being opened
Hello guys, While i was working my laptop suddenly shut down with no reason and won’t turn on again, I tried:
1- Booting without battery plugged in and it failed
2- Changing CMOS Battery and didn’t work
I found that when i open the lid the laptop turns on and keep restarting (exactly like someone keeps pressing the power button), I tried to connect the laptop to an external monitor then i opened the lid for 2 secs and closed it again, The laptop turned on successfully without any problems on the external monitor, but once the lid is open again it goes for infinity loop as mentioned above, I suspect that there is a conflict in the power cycle that causes the lid pressing the power button once it’s opened and i don’t know how to solve it, Any suggestions?
Thanks in advance :)
3条评论
Hi,
Have you checked the advanced power options so see what the "Lid" settings are?
Also what are the sleep and Hibernation settings? Try turning them off if on.
Also have you tried shutting down the laptop by holding the power button until it fully shuts down? Just in case it is a sleep, hibernation, lid conflict? Doing this should get it out of sleep or hibernate state and mean that it is reallyturned off.
由 jayeff 完成的
Hi @jayeff,
Thanks for your reply, I tried these options too, turning off all power options neither to power off nor even sleep, The same result.
power button doesn't work under any case unless i open the lid, So my case now is:
The lid is open = The power button is held
To keep the laptop turned on i have to open the lid and close it quickly so this means the power button is pressed just one time and the device is turned on successfully and i can manage it from an external monitor normally, otherwise the power button doesn't response to any interaction from me, i tried holding the power button for nearly 1 min and nothing happened.
I hope i could explain my problem right since English is not my native language
由 Yusuf Issa 完成的
I had the same problem and I fixed it by this Link… https://youtu.be/DS4gIEfbS4Q
由 Md Manjurul Islam Rubel 完成的
