iMac Power Supply Test
How do I test the power supply is faulty
do u have a multi meter, if yes then you can check whether you are getting proper output as specified in the power supply or not. if not then you can try borrowing a friends power supply and connect it to your device and see if your device works, if it does then your power supply will be faulty.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,106
