跳转到主内容
加入维修社区 - 创建账户
Guides and repair information for coffee and espresso makers from Jura Elektroapparate AG, a Swiss developer and distributor of home appliances.
coffee beans won't grind
grinder makes grinding noise but does not grab the beans (fill beans demand) I already emptied all the beans out and let it ‘dry’ according to helpline but it still does not work
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Do you see the impeller spinning? Using a plastic straw wedging it into the blade does the blade have force?
My coffee grinder (different) had a sheer pin which snapped so the impeller was not secured to the motors axle so the motor ran just no grinding!
Use care! As you don’t want to use much force holding the impeller and you don’t want to put your fingers at risk either!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
anja 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 558
