跳转到主内容
Annke CCTV has died
My Annke CCTV was working fine till I stupidly plugged a USB mini fan into it. The fan ran for about 10 minutes then stopped and now I have no power at all to the cctv.
I’ve taken board out and where the power goes in there is a large black square component. Can anyone tell me if its a fuse. The supply is 48volts. There is no continuity across this component.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @boness
TVS - This is a TBS - Transient-voltage-suppression diode
I see it is powered by an external power adaper.
Do you have a multimeter?
Measure and check on if the power adapter is giving the out correct voltages.
这个答案有帮助吗?
得分 2
2条评论:
Hi, thanks for your reply. I have checked the psu and it is working
完成的
take more pics , showing up the whole mainboard.
try removing the mainboard and check if there are any burnt components
完成的
添加一条评论
添加你的答案
Gordon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 10
总计 165
